mholhut
My fluid level sensor has been shot for the past year or so, and the display always says "low washer fluid" which means that even though there's fluid in the resevoir and the fluid will spary, the wipers won't come on... because the car thinks there is no washer fluid.
The only way to buy the sensor, is to buy the whole resevoir... for $80. Made an attempt to buy one from a guy who was parting out 3 LS's on Ebay, which failed epicly. So, I'm wondering if there's a way to trick the sensor into thinking there's always fluid in the resevoir. I know some older-style sensors you could just ground one of the wires and it would do the same thing. Not sure if that would apply to the LS.... might need a resistor?
Suggestions?
Suggestions?
