Walbro fuel pumps
Jibit
Dearly Departed Friend
Villa Park, IL
what are the part numbers for walbro fuel pumps that are direct replacement for the marks? I can find the 255lph all over the place but I'm looking for the 190 and 150lph pumps. I know of places that sell them but I can find them cheaper else where if I only knew the part number, plus I need it asap! Hopefully I might be able to find it at a local hp shop iun the area.
If it's for your 2nd gen, get the focus pump directly from Ford.
It will fit better than Walbro and it will be quieter. It's also cheaper.
I would listen to this man........
If you want the low pressure unit then GSS317 is the correct part number, if you want the high pressure GSS342 is the correct part number. Also, you need everything that is included in the kit that is shown on their website.
