W3z3 ecu
Htrlman1
Spring
I pulled the w3z3 out of a 93 is it a better swap than a w3z2? I read the other post but no one said anything about the w3z3. Anything helps guys
I've seen posts that the W3Z2 is better than the W3Z3, i'm sure others will post.
they are close.
the z2 has more timing and more trans line pressure.
i didn't notice much difference myself. but my trans already had the jmod.
the z3 did have better mileage though.
Well I have another ecu the original out of the 95 but I don't remember the Id on it, I'm away. But it's chipped, and I need to get the chip reprogrammed. I'm going to put the w3z3 in and see what it does. I'll be on the look out for a z2. I'm really looking for better spark and what not lol
The chip should be doing that for you if it's being programmed correctly. If you have a 95 original, it should be a DZA1 and if you took that chip and put into a Z3 or Z2, it would be just as equal. If you want to do away with the chip all together and go with a stock, aggressive tune, the Z2 is the one. If someone were take your chip and had the tune from a Z2, it could be burned onto your chip that's in the DZA1 and be the same.
W3Z3 WOT spark
6000.000 27.0
5000.000 24.0
3500.000 23.0
3150.000 19.0
3050.000 14.0
2500.000 12.0
2000.000 12.0
W3Z2 WOT Spark
6000.000 32.8
5000.000 29.0
3500.000 26.5
3150.000 22.3
3050.000 17.0
2500.000 15.0
2000.000 13.0
W3Z3 Rev Limit 6450
W3Z2 Rev limit 6850
W3Z3 1-2 shift 5600
W3Z2 1-2 shift 5600
W3Z2 speed limit (driveshaft revs) 16372= no speed limiter
W3Z3 speed limit (driveshaft revs) 5400 = max speed limited!
Shift pressure on the W3Z2 PCM is 15 PSI higher.
W3Z3 WOT spark
6000.000 27.0
5000.000 24.0
3500.000 23.0
3150.000 19.0
3050.000 14.0
2500.000 12.0
2000.000 12.0
W3Z2 WOT Spark
6000.000 32.8
5000.000 29.0
3500.000 26.5
3150.000 22.3
3050.000 17.0
2500.000 15.0
2000.000 13.0
W3Z3 Rev Limit 6450
W3Z2 Rev limit 6850
W3Z3 1-2 shift 5600
W3Z2 1-2 shift 5600
That's great thanks for that info, I'm going to put the z3 in, so the chip basically will work in the z3 cause my ecu is the one you said.
