I am thinking of installing a kd-nx5000. I know its old but the fact that its single din makes for no mods. Anyway, I found before somewhere that there is a VSS wire in the dash. Does anyone know which it is?
Well unless I can hook it up to the data wire, which i doubt, to the ABS module it is.
All of the FORDs I've owned with the cheesy auto volume thing, used a VSS wire. If your factory radio had that feature, there's a good chance the wire is there in the harness.
this is true with all of the old OBDII cars, but is usually (with most of the exceptions being the inbetween years ) not true for CAN cars.
with most cars that use a CAN system, all of the different modules are basically talking to each other through the bus, as joe mentioned, this is how the radio gets a lot of its info, they do make integration wire harness that do tap into the cars CAN system and reads all of the info such as P-brake,VSS, reverse,and off and on including RAP. but i dont think that i have seen one that works with the LS. all of the radios that i have seen it work for dont have an ACC wire at the radio.
what does the steering wheel resestance wire have to do with the VSS wire?but I do know it goes directly from the clockspring to the radio.. I believe it sends different frequencies and the radio interpret them.. If none of this is correct, what are you asking?
Do you think I would have any complications if I didn't hook up the wire?
