Vortech V2 S-Trim
97MarkJA
Forest Lake
I have a V2 S-Trim for a 96-98 Cobra that I purchased from another member here, the unit was the car for several years and logged about 7600 miles. I purchased a new hardware kit with updated idler pulley from vortech (still in packaging) as well as a C&L intake. It has the normal cosmetic wear here and there but the wheel has zero play and zero nicks.You will need injectors/fuel pump of your choice, air filter, vacuum line and a oil pan drain tap, otherwise I think everything is here. It still has the factory pulley on it.My motor build has lead me to an upgrade, I've had this tucked away for over a year; never got to install it and need to upgrade already.You can email me directly at agent1241 at gmail.com$1800 obo shipped to the lower 48I'm not looking to separate anything and based on the prices I've seen its a pretty good deal. I can ship directly from work daily through ups with the exception of Sunday.
This will work on a Mark using a cobra intake or any gen1 or 2 with a little work on the discharge tube.
