Had good luck with mine, trying to help a friend out, no luck on eBay or anywhere. Liked the mid priced option. Anybody have a source? Delphi via RockAuto my next best?
Thanks in advance
Paul
The V8 Visteon's are apparently permanently unavailable new.......
Roger that, thanks for the knowledge. Weird that the V6 versions are. I know there are threads all over about COPs but I'm not interested in HiPo just a serviceable mid level replacement. Not digging the Motorcraft price, any experience with Delphi or similar?
I thought the fact that you can get the v6 version just about anywhere was strange too.
You would think if you bought the vs version and used the v8 boots it would still work.
I wonder if anyone on the site in the past tried this v6 on a v8 conversion.
If I'm not mistaken the V6 used in the LS is a standard Ford V6 used in other makes, so would be more readily available. I would wonder if Jaguar V8 COPs might not work on the LS seeing as Jaguar continued with the AJ engine long after Lincoln stopped using them. I was able to get cooling system gaskets from my local Jag dealer with no problems, after my local Lincoln dealer couldn't even find the correct part number.
Pic or it didn't happen?
If you ever see me post an ad for 7 good slightly used OEM Motorcraft coils, you'll know the Visteon's went in.![]()
