luxuryrules
Springs can be made softer than the air ride and stiffer than the air ride, but not both. Air will absorb the small bumps and keep things nice & tight in the corners... it's a win-win situation.
Since you already bought the springs, either return them or sell them off, or stick them in your garage until the air gives you a problem you can't solve. Short version is that, in your quest to improve your car's handling, coils are a step backwards.
Put swaybars in it, get a set of Firehawk Wide Ovals, and get Cobra shocks for the rear with metal shock mounts & poly bushings. When you are ready to take it to the next level, look into using Bilstein inserts into the front struts and swap all the chassis bushings to poly.
