Tony_1992
The last time I replaced the spark plugs, I found some engine oil deep in the tubes around spark plugs. It looks like a classic problem, leaking of O-rings around spark plug. So I decided to replace them. Here are some questions:
- Do I need to fully remove all of the four spark plugs to lift the valve cover up and replace the o-rings? I really don't want to contaminate the combustion chambers.
- I'm thinking of buying this sets of gasket from rockauto: More Information for FEL-PRO VS50724R . Does it comes with all things needed to finish this job? Do I still need to by some other materials?
