NickLS
Hey everyone, I would like to know if anyone that has a aluminum or stainless steel tube from lskoncepts have clearnce issue when trying to close the hood??
I am going to use the following picture w/ numbers for reference
(a pic I snagged from MDDave to show since it was about 2am and only had a flashlight when I installed it)
I installed my new tube last night and everything went smoothly, but I did notice that the tube did sit kinda high.
The S-bracket (#4) is what is making the tube ride high in my opinion. After installing all the tubes and filter, I tried to close the lid. Closing the lid slowly, i looked for clearance between the tube, filter, etc., and the hood. The hood hit at all points of #2
I think the S-braket's groove wasn't cut deep enough. Because I know that LSKoncepts uses a jig to create and weld everything together.
Anyone run into this problem??
Quick Tip: Install the plastic tube that fits into #1 FIRST before you put the intake in.. Take the tube out, take some sandpaper and sand the plastic end till it's about the same size (alittle bigger) than the ID of the tube. Then put the tip in boiling water for about 10-15 seconds to get it alittle pliable, then immedietly SHOVE it onto the tube, it take alittle work, but it'll go on tight and snug. Another thought is to take off the rubber o-rings.
