cammerfe
All this 'massaging hoses' bit sounds kinda kinky to me!!
KS
KS
...Looks like the DCCV took a crap on me. Will be replacing that soon. And the aux pump.
Well, it could be the DCCV, but it probably isn't. Those mostly fail in the open position, and it wouldn't have given you heat while bleeding it. I'm betting that it's air in the heater loop that's preventing circulation.
Did you fully (or at least mostly) drain it and refill and bleed exactly by the gen I procedure?
I suppose it could be the aux pump as it would be hard to correctly bleed it without that working.
I didn't drain the system at all I just drained the degass bottle put the new one in and top everything off. I got heat that time but just now I got nothing plus the hoses at the heater core feel like they are empty, very spongey when pressing them.
Yes I bled the system to the T per instruction, I just finished bleeding the system again and I noticed that at the engine fill the level was real low ...
The point to draining it and filling per instructions is that it allows a path for a lot of the air in the system to escape before you ever get to the bleeding part.
That's a good sign that all the air wasn't bled out and/or you have a leak somewhere.
It's a dorman degass bottle ( can I at least finish my cigarette before you guys slap me in the mouth.) lol
It's not getting any heat now at idle or 2000 plus RPMS, the system is holding pressure from what I can tell. I let it idle with the ac on for at least a hour and no signs of overheating.
Also I have a Stant cap not the one dorman has on the bottle. that fits on it so tight I had to use channel locks to get it off.
KS
