Keviiin I used an 18mm ratcheting combination wrench and a little patience. There is enough space between the master cylinder and engine to fit the wrench through and using another combination wrench for leverage was able to remove it with little trouble. Had to go to the ACE on NW Highway to get a magnet and retrieve the nut after dropping it. Took a little over 2 hours to switch them out. The 18mm wrench allows you to not have to remove the tube or anything. If you need one you can use mine, don't buy the one from advance for $20, ACE sells the same thing for $15.
I am using napa's master chasis control arms. They are about 2x thicker than stock and have a replaceable ball joint. The ball joint socket is where you can grease it regularly and is considerably larger than stock.
