Staffamerica74
Alright so I finally finished my 04 trans and tc swap into my mark, I changed output shaft and ring gear. Wired it all up using the 04 hard internal harness, 93 tcc, 95 mlps, 04 shift selenoids. Repinned the harness did everything right.... All i get is 2nd gear when I put it in Drive. If i manually put it in 1st or 2nd I still only get 2nd. Its as if its in "limp in mode" if Ford even has such a thing.
Then tonight when I was sweeping the garage I saw somethink on the floor... It was a little transister. Just like the one in the internal plastic harness I am not sure if it is it or not but if it is, would it cause this issue... I am so fed up right now...
