Two types of sway bar bushings?
fudge12
Brooklyn
I saw a few sway bar bushings for the front but different diameter. 28.5mm and 30mm. which one do i go with?
What year?
V6 or V8?
Sport or non-sport?
sorry lol. 00' v6 non-sport.
Also I found this knocking around hanging off one end :3
I'm also starting to hear some loud creaking as i go over bumps. Could the others be going on their way out causing the creak?
i replaced the rear stabilizer links on the car yesterday and took it out for a spin on the highway. The car feels a LOT more better and doesn't feel like i'm losing control at higher speeds when I'm switching lanes. The front ones are definitely due for a change as well.
Anywho, 28.5 or 30mm bushings for this car?
gen 1 (00') v6 non sport ls.
The small one. The larger one is for sport suspension, which is on the sport cars and a few others (e.g., '02 "premium")
Don't think you need that part, doesn't look all that important, just go ahead and throw it away, care on, no worries!
fudge,
grab a small piece of straight narrow paper, crawl underneath at either wheel, measure sway bar by means of wrapping paper around diameter of bar. Use pen to make a mark, measure with ruler.
... either that or borrow/use a vernier caliper.
Wrapping paper and reading length will give you circumference instead of diameter. You'd need to do the math using C=Pi D.
KS
I see now that it was late after a long day. To error is human! Silly me!
