I've got this problem with my car at the moment........haven't had time to take it in yet, but was wondering what you all that about this. Any techs out there that know anything about this or what I should do? Thanks a lot.
Article No.
99-26-8
12/27/99
^ BRAKES - "POPPING" NOISE FROM THE BRAKE
PEDAL AREA, WITH POSSIBLY PEDAL
MOVEMENT - VEHICLES WITH ADVANCE TRAC
VEHICLE STABILITY CONTROL SYSTEM BUILT
THROUGH 10/11/1999
^ NOISE - "POPPING" FROM THE BRAKE PEDAL
AREA - VEHICLES WITH ADVANCE TRAC VEHICLE
STABILITY CONTROL SYSTEM BUILT THROUGH
10/11/1999
LINCOLN-MERCURY:
2000 LS
This article only applies to vehicles equipped with Advance Trac vehicle stability control system. Vehicles equipped with Advance Trac can be identified by the letters ATS on the traction assist cancel switch located on the center console.
ISSUE
An intermittent "popping" noise coming from the brake pedal area under normal driving conditions, with possibly movement of the brake pedal, may occur on some vehicles. This may be due to a strategy concern within the Electronic Control Unit (ECU) of the Anti-lock Brake System (ABS) and Advance Trac System.
ACTION
Replace the Anti-lock Brake/Advance Trac ECU with the revised ECU. Refer to the following Service Procedure for details.
Article No.
99-26-8
12/27/99
THROUGH 10/11/1999
10/11/1999
LINCOLN-MERCURY:
2000 LS
ISSUE
ACTION
