xxdjdinot1989xx
wtff!!!!!!! i opened my trunk today and i pull the thing up to just see if my window spray is there and i noticed all this water
i did check if it was leaking anywhere didnt see anything
also - grommlets on the rear taillights and draining on the bottom of the trunk tub.
Get in the trunk with a flash light and have someone run a water hose all along the trunk seal, tail lights etc.
I noticed moisture in my trunk, have you found out what's causing this?
