Trunk pull down doesn't work.
The Owner
Stockholm, Sweden
Hi,
I've a 2003 Cartier and the trunk pull down don't work. I've to close the trunk by hand, it close/lock the trunk the last bit as normal. I've to open it with the key, if I try to use the open button on the door or remote keyless I can hear a "click" sound inside the door, but the drunk doesn't open.
Also the light inside the trunk doesn't work (I've checked the bulbs).
And I've fault code B1342 ECU IS FOULT.
I've checked the fuses.
What could be wrong, any suggestions?
Thanks
lid codes
I do not know if this helps but......
Luggage Compartment Lid Module Diagnostic Trouble Code (DTC) Index DTC Description Source Action
B1342 ECU is Defective Luggage compartment lid module INSTALL a new luggage compartment lid module.
B1359 Input Low When Key in RUN/START Position Luggage compartment lid module Go To Pinpoint Test A.
B1551 Latch/Lid Release Circuit Failure Luggage compartment lid module Go To Pinpoint Test C.
B2418 Sensor Power Short to Ground Luggage compartment lid module Go To Pinpoint Test B.
B2419 Sensor 1 Invalid Luggage compartment lid module Go To Pinpoint Test B.
B2420 Sensor 2 Invalid Luggage compartment lid module Go To Pinpoint Test B.
B2421 Vehicle Speed Sensor Circuit Failure Luggage compartment lid module Go To Pinpoint Test C.
B2522 Vbatt 1 Circuit Failure Luggage compartment lid module Go To Pinpoint Test A.
B2552 Vbatt 2 Open Luggage compartment lid module Go To Pinpoint Test A.
B2698 Vbatt 2 Circuit Failure Luggage compartment lid module Go To Pinpoint Test A.
B2703 OPEN CLOSE SW Input Stuck Active Luggage compartment lid module Go To Pinpoint Test B.
B2718 Lid Ajar Output — Short to Battery Luggage compartment lid module Go To Pinpoint Test B.
B2721 Lid Ajar Output Circuit Failure Luggage compartment lid module Go To Pinpoint Test B.
B2748 Drive Motor Open Circuit Luggage compartment lid module Go To Pinpoint Test B.
B2755 Drive Motor Short to Battery Luggage compartment lid module Go To Pinpoint Test B.
B2757 Drive Motor Output Short to Ground Luggage compartment lid module Go To Pinpoint Test B.
B2825 Obstacle Detection Path of Decklid Luggage compartment lid module Go To Pinpoint Test B.
B2876 Striker Drive Short to Battery Luggage compartment lid module Go To Pinpoint Test D.
B2877 Striker Drive Output Short to Ground Luggage compartment lid module Go To Pinpoint Test D.
B2905 Striker Motor Open Circuit Luggage compartment lid module Go To Pinpoint Test D.
B2906 Striker Up SW Input Invalid Luggage compartment lid module Go To Pinpoint Test D.
B2907 Striker Down SW Invalid Luggage compartment lid module Go To Pinpoint Test D.
B2908 Latch SW Input Invalid Luggage compartment lid module Go To Pinpoint Test B.
B2910 Striker Up SW/Striker Down SW Mismatch Luggage compartment lid module Go To Pinpoint Test D.
B5131 Clutch Circuit Failure Luggage compartment lid module Go To Pinpoint Test B.
C1123 Vehicle Speed Sensor Circuit — Fault Luggage compartment lid module Go To Pinpoint Test C.
Symptom Chart
Symptom Chart Condition Possible Sources Action
No communication with the luggage compartment lid module
Luggage compartment lid module.
ISO-9141 circuit 70.
Circuitry.
Luggage compartment lid latch opens, lid motor inoperative
Luggage compartment lid motor.
Circuitry.
Luggage compartment lid latch inoperative
Luggage compartment lid latch.
Driver door module.
Circuitry.
Luggage compartment lid closing motor inoperative
Luggage compartment lid closing motor.
Circuitry.
and there is plenty more where that came from.
max
If it is the module (code b1342) it is under the rear package tray...6w7z-14b169-a listing for 342.24 and LVC is 192.51 plus shipping
max
Thanks mrzeee for your reply.
I'll try to do the pinpoint tests to see if there might be a bad connections.
Sorry but what is a LVC?
Where can I buy the part(s) (if they are broken), part(s) needs to be shipped to Sweden.
Thanks
Hi,
Is this the lid module?
Thanks
I did some pinpoint tests,
I checked the power and the ground to the lid module - all ok.
And did verify the integrity of the luggage compartment lid motor - all ok.
For me it look like it's the lid module that are bad. :(
Any suggestions?
"LVC" is your "LVC" discount price. Happy to hear the concern is resolved.
Max
