Ron Sircar
Hi all
I'm having some issues trying to pull codes from my 2003 Lincoln LS V6, initially when I got the car it had a no start issue related to PATS, I eventually managed to resolve that by swapping in the ECU guage cluster and ignition switch from a running 2004 Lincoln LS V6.
Now that the car is running, I am trying to read codes to find out why the check engine light is on, I borrowed a generic OBDII reader from a friend, however it keeps reporting error when I try to download the codes to see whats going on
Is there any preferred brand of reader I should try or are all pretty much the same? would there be an issue because I changed ECU's? or does this indicate an issue with the wiring harness itself?
