sprocket
Hello, I have a '96 Mark VIII, 204,000 miles.
I'm getting occasional misfires. The CEL flashes. It usually lasts about two minutes at most, occasionally will come back several minutes later, and often clears up for several days at a time. It appears to be worse on hot days with the A/C on. Here's the codes I am getting:
P0141
P0156
P0161
P0301
P0307
P0308
The misfires are from both coil packs and I think from three different coils. I can't see it being a coil pack issue. I'm a little confused. It looks like I have a bad bank 2 sensor 2 O2 sensor. But there's is also a code for the bank 1 sensor 2 O2 sensor.
But both those sensors are past the catalytic converter right? They don't control engine management?
Are the misfires resulting in fuel in the exhaust and that is why those O2 sensor codes are set?
Bad PCM?
Thanks for any help
P0141
P0156
P0161
P0301
P0307
P0308
Bad PCM?
Thanks for any help
