Thanks for taking the time to read this I really appreciate it. I have a 2000 LS 3.9L. I have replaced all 8 ignition coils and a ton of various other problems. This one seems to be a killer though. The check engine light came on, then got an E in the drive computer (instead of D5, D4 ect). Now the rpm's don't downshift at high speeds. At 75 mph I am at 4000 rpms. The computer said that it was a solenoid problem, so I replaced that to the tune of $700. Though the problem was fixed, but first time a freeway all the lights came back on and rpms are through the roof. I talked to a tech at lincoln and he told me to replace the valve body kit, that "might" work. I don't want to pay $1000 for a maybe fix. Do you have any other ideas what this might be, or have you had the same problem.
Thank you so much for any and all advice.
