DomiDotso1
Hello I currently own a 2002 Lincoln LS V8 and I can not get it to shift into drive. It will start up, rev up, and shift into park, but when I shift into drive the car immediately stalls. The oil pressure light, battery light, and check engine light comes on when it stalls. The code that comes up is a P0113 but I have tried replacing the Idle air temperature sensor to no avail. I have recently replaced the clock spring and the driver side center wheel hub. It has hesitated when shifting between park and drive in the past and the shop quoted me $2,500 for a rebuild but could not explain why it needs to be rebuilt. Any help would be greatly appreciated!
