My transmission is acting crazy. The day that i went to go fix my solenoid issue, my transmission started going forward in reverse gear and also in neutral gear. This was before i even opened or touched anything . I manage to swap out my solenoid and took care of the E. i also switched a 4-3 prestroke spring and got rid of the shaking.
I still have the issue where my transmission is going forward instead of reverse. I was thinking it could be the linkage cable not adjusted correctly. The GEAR R AND N are showing in the cluster, but the car is going forward in R and N. Has anybody dealt or heard of this issue before. I would like to know if it is possible to fix with a new valvebody
car is a 2000 lincoln ls V6 5r55n. Any help would be appreciated. I tried searching but couldn't find anything similar.
