Transmission control switch question
raido1980
Troy
I'm having an issue where I can't get the o/d button to work. I've checked everything except one red wire with a yellow stripe. I'm wondering if anyone can tell me what this wire is and where it goes. I am at a complete loss. Any help would be the bees knees.
The od button is fine. I ran tests with my dvom. The last thing to check is this red wire with a yellow stripe. I just don't know what it is, or where its going. I can't find it on the info sheets that I have.
Mine has a broken wire inside the console from the shifter flexing it. It works in park but thats all. I found that out by moving it around when i had the shifter bezel off.
Been meaning to change the wire but havent got to it.
My 93 had the same problem and after searching on here I found most everyone had the same problem ,wire actually broken inside the shifter boot going to the button. pulled mine off and sure as s#@t that was it.
