02 ls8
ok so i have a 2002 LS v8 with 86k on the trans, and the problems i currently have are that when i drop the car down into first its almost like its in park and the car doesn't move and wont go, it feels like you sitting there with your foot on the gas and brake, if you sit and wait with it in first gear though for maybe 45 seconds it will work though, at first i thought maybe a valve was stuck or something but then i when i drive it in normal d5 i count it shift 5 times meaning 1st has to be working, the second problem is that d4 went out, in other words i can put it in d4 and it stays in d5 on the dash and wont down shift per-say i was on the freeway and did it, no i considered flushing the fluid not that long ago but everyone i know who does a flush has there auto trans blow shorty after, its almost as if all that crap inside helps it, thanks for your help
granted i need to rebuild the entire front end still ever since i got pushed into the curb by a truck but i only need a dash airbags steering wheel and a windshield now so getting close
