Trans issue
Call Ended
Clearwater
04 LS V6. Was getting hard shift from 2nd to 3rd and 3rd to 4th. As well as hard engagement from Park to drive or to reverse. Did a bunch of research came to the conclusion most likely it's the solenoid pack. Went to Ford had them reflash my computer(free). Didnt help. Also put new solenoid pack in.
After solenoid pack install still hard engagement into Drive or reverse but not as frequent. Also still rough shifts 2nd to 3rd. Not as rough as before replacing but still exists.
The day after solenoid switch out when I come to a stop the car stalled. Turn car off turn car back on drove normal besides shifting issues. Now intermittently when I come to a stop and try to take back off it seems as if there is zero power when I push the gas pedal for a moment or as if the transmission is slipping a bit to engage into gear.
My question is with a new solenoid pack and computer reflash any ideas what could be causing this issue as well as what may have been done to cause the newer issue. I have read that it could be the valve bodies but I'm looking for more Direction before I tear transmission open again. Thanks
