Outkast
As some of you know, I just recently replaced my left rear wheel bearing.
this week, at first it was fine, then on tuesday, the check traction control light came on along with the abs light.
If I shut off the TC then it seems to be fine, but if I leave it on, then when I accelerate, (without spinning the tires) it acts as if the tires are spinning and cuts the cylinders out.
any idea where to start? does autozone check abs codes? if I drive 5-6 miles the check traction control light and abs will illuminate, but reset if I shut the car off.
