Traction Control/ABS problem
TheBigRedOne
Montgomery, AL
I had my new '98 LSC at the dealer for the cruise recall so I had them pull the ABS codes since I have an ABS light and Check Traction Control light. They said it was the left rear sensor. I took the sensor off my '94 and replaced it on my '98 and it still has the lights. Are the Gen2 sensors different?
not only are 98 sensors all by themselves, but they are obsolete too. you will have a very hard time locating them. you should have looked closer when you swapped there is a large physical different in the size of your 98 pick up vrs the 93-97 abs pick up.
damn that was my plan. my RR on my 98 goes on the fritz when its cold out (below freezing) i was hoping it was just a different plug or something easy to swap over.......any one got any pics
