top ball joint?
jrk042385
west lafayette
I just got my lower ball joints replaced but there it still a light clunking sound i noticed the top ball joints are worn could this be the cause?
Also if anyone knows where to get these without paying out the A$$ that would be great
If I am reading this correctly, you are referring to the upper control arm that connects to the knuckle at the top?
I have one coming from Max at 5 Star Ford (see ad to the right). Also check out Team Ford to the right.
PLEASE NOTE that you need to know if you have a 14mm or 16mm bolt/nut. The bolts are a unique design.
