greatness
has anyone had there timing chain replaced on a V6 and if so how much did it cost
and has anyone ever replaced it by themself
I would say at least 1k if you have someone do it.. maybe even more..
You can do it yourself if the valves haven't hit the piston..
Prolly will cost more than $1000 seeing it broke while going down the highway. It will cost that if you do it yourself and more if someone else does it. A piston definitely hit a valve seeing it was running when it broke. These are zero tolerance motors so it hit a piston.
To Greatness: to fully know the damage, you need to take off the valve covers to see if it was a secondary or primary timing chain that broke. If it was a secondary chain then just the head on that side needs to be taken off and fixed. If it was a primary chain, then both heads would need to be removed and fixed. Good Luck!!
have u replaced it urself before
Drivers side is the sh!tty side too..
one rotation of the motor - driving or not - will have valves hit pistons....
to pull the heads off an LS is $1000s - and it is the only way to know for sure how bent the valves are and how mashed the pistons are...
you cannot buy a piston, so if a piston is damaged, you are swapping engines - since swapping a loaded block costs more...
so i should just buy a new engine
I have a one of those cameras that you can feed into the spark plug hole and scope around - but it's still very tough to see if you bent the valves - if the chain is broke you can't rotate the engine to see everything close nicely - so unless the damage is very obvious it hard to be sure....
