Timing Chain Set
From the SAME page you posted!
This part is compatible with 11 vehicle(s).
Year Make Model Trim Engine Notes
1997 Ford Mustang SVT Cobra Convertible 2-Door 4.6L 281Cu. In. V8 GAS DOHC Naturally Aspirated FULL
1997 Ford Mustang SVT Cobra Coupe 2-Door 4.6L 281Cu. In. V8 GAS DOHC Naturally Aspirated FULL
1997 Lincoln Continental Spinmaker Edition Sedan 4-Door 4.6L 281Cu. In. V8 GAS DOHC Naturally Aspirated :q
1997 Lincoln Mark VIII Base Sedan 2-Door 4.6L 281Cu. In. V8 GAS DOHC Naturally Aspirated :q
1997 Lincoln Mark VIII LSC Sedan 2-Door 4.6L 281Cu. In. V8 GAS DOHC Naturally Aspirated :q
1996 Ford Mustang SVT Cobra Convertible 2-Door 4.6L 281Cu. In. V8 GAS DOHC Naturally Aspirated FULL
1996 Ford Mustang SVT Cobra Coupe 2-Door 4.6L 281Cu. In. V8 GAS DOHC Naturally Aspirated FULL
1996 Lincoln Continental Anniversary Sedan 4-Door 4.6L 281Cu. In. V8 GAS DOHC Naturally Aspirated :q
1996 Lincoln Continental Spinmaker Edition Sedan 4-Door 4.6L 281Cu. In. V8 GAS DOHC Naturally Aspirated :q
1996 Lincoln Mark VIII Anniversary Sedan 2-Door 4.6L 281Cu. In. V8 GAS DOHC Naturally Aspirated :q
1996 Lincoln Mark VIII LSC Sedan 2-Door 4.6L 281Cu. In. V8 GAS DOHC Naturally Aspirated :q
Whats your point? The ad says 96 & 97 like he said. He asked if it fits other years. It does. It will fit all Marks from 93-98 cause the timing setup is identical.
Thank you Laser, for reading my question correctly. =] The other timing set I found on Rock Auto is 425 and other 475. =/ I have 900 to fix my car, so I am trying to get as much parts as I can, but I want them to be good quality also, then again never heard of the above mentioned company.
