Timing chain question
CartierBear
Tulsa
How often do you change the timing chain and how do you know if it needs replacement? My TC has 272K miles and it runs fine i was curious if timing chain could be a problem. it was a one owner corporate vehicle so i assume maintenance was done
What year is your car?
The timing chains on 91+ (modulars) seem to last forever, but if you have a 2000-2003 model the chain tensioner guides are defective and wear quickly, which will let the chain eat into them (and causing a number of issues as a result, including potential oil pressure loss and engine failure)
So if you have a 00-03 you should have them replaced with the revised guides ASAP - especially if over 75k, before anything significant happens.
There is a TSB on this issue; 03-15-7
