Roadboss
Here's an off the wall shot. How about a marginally loose spark plug.
heck I run mine well into an past the redline.
commanding the 1-2 shift at 6500 and it actually completes the shift somewhere in the 7200 range.
Would I suggest others do that.. NOPE.
but I aint scared to break something either..haha
How many motors have you gone through in 400k?
How many transmissions?
My original engine that was still running when I pulled it out lasted until 360,000 miles. It had tossed the secondary cam chain tensioner, and was making more racket than in the youtube video above.
I drove it for 25K like that, and since the noise only happend on start up, the motor likely would have lasted many more miles... BUT...
I was knee deep in the middle of a season long points race "Street Stock Bracket Race" and I was in First Place, so I didn't want to take a chance on having the engine "toss itself" while "on the track"....so I replaced it.
Transmission, my original transmission lost reverse, well it still HAD reverse but it shuddered really bad when backing up...
SO I secured a 98 LSC trans and dropped it in.
I dont attribute either of those failures to "high RPM".
The nylon pad on the cam tensioner finally "wore thru".... I could have easily just replaced the tensioner and went on with life.
IMHO it was much easier to "R&R" the whole engine than it was to start taking it apart to find and fix the source of the noise.
SO in short.. to answer your question.
I have been thru 1 motor and 1 trans in 360,000 mile and well over 5000 dragstrip passes {which comes out to about 1100 miles of WOT)
