theophile
'02 V8. I rarely have passengers so therefore usually have the temp set for the same on both sides. Yesterday I went to Gulfport (joegr's neck of the woods) with a colleague who likes his air a little colder than I do. At the end of the day, after I dropped him off at his house, I was pulling out of his driveway and felt the air coming out of the driver's side vents suddenly become very warm. It now blows hot on the driver's side but nice and cold on the passenger side.
I know this is a classic indicator of DCCV failure. But the only reason I haven't already ordered the new part is because every thread I've read here about this issue, the symptom is the opposite of what I have going on. Normally, the poster is complaining about the driver's side blowing cold and the passenger side blowing hot. Here's what I've done to narrow this down to DCCV:
* I did the DATC self test and it passes with no codes. There are also no continuous DTCs registered.
* I monitored the A/C sensors with a scantool, and it shows the driver's heater temp and the passenger's heater temp having a temperature differential of around 20 degrees C at operating temperature, suggesting it's not a temp sensor malfunction.
* Starting the car cold, monitoring the live sensor data, and setting the controls to 60 degrees, I can see the A/C core temp at around 3-4 degrees and the driver's and passenger's heater temps start out at about the same value. The air coming out of the vents feels cold and about the same temperature. As the car warms up, the driver's side temp sensor climbs noticeably faster than the passenger's side, which coincides with the vent air getting warmer.
* There don't seem to be any coolant leaks, although the coolant reservoir does appear to be a bit on the low side. I will check it again in the morning when it's stone cold.
* There are no readily apparent signs of refrigerant leak, although I did not inspect very closely because the A/C system does appear to be cooling the air, it just gets overpowered by hot air on the driver's side.
* Fuse #1 is not blown.
Again, I realize that all this points to the DCCV, but I just wanted a sanity check because I haven't run across another thread where someone has heat on the driver's side but cold air on the passenger side. Then again, if the DCCV is going to fail and cause one side to stick open, I don't suppose there's a reason it would only be the passenger side of the valve.
Anyway, I'm about ready to order the DCCV but if you think there's something else worth checking first, please let me know. And on the subject of ordering, does anyone have anything good or bad to say about the "Four Seasons" brand part?
Thanks all!
Thanks all!
