BrklynExpress
What components can we swap into an LS from the thunderbird. is the dash plug and play? What about the nicer leather seats?
What nicer leather seats? They're the damn same.What about the nicer leather seats?
If by "dash" you mean the instrument cluster (as opposed to the center stack or trim), that's definitely not plug and play--no dash is plug and play in the LS. It should work, but it has to be "married" to the PCM by a FLM dealer (or, IIRC, someone with a Ford NGS tester) because it contains the odometer information.What components can we swap into an LS from the thunderbird. is the dash plug and play? What about the nicer leather seats
As to the cluster
to make it work it would be easier to swap the faceplate.
You have to be careful pulling off the instrument needles.
Once off there are 2 spots of glue at the bases of the big needles that have to be gently cut with a boxcutter blade.
5 minute epoxy can be used to glue in the new faceplate at the same places.
The needles are powered by small electric motor type devices.
Once the cluster is reinstaled the needles will do a sweep to reset themselves.
Since you use your original cluster there is no marrying to pay for or worry about working as a dealer will not guarantee a customer supplied used cluster.
You also don't have to worry about the pc language.
Gen 1 and Gen 2 clusters will not interchange.
Gen 1s are PWM and Gen 2s are CAN.
A Gen 2 car won't even start unless it's married to the car.
Gen 1s will start but beep in reverse and at over 70 mph until married.
Not sure which one the Tbird is.
I put a Gen 1 metric faceplate on an extra Gen 2 cluster I have but am going to take it out and put it in my original cluster due to this "married" to the car stuff.
I have no clue how right or wrong you are... but that is a pretty damn good idea. It avoids all the dealer and will it work BS. This project becomes a simple face swap (compared to getting the electronics to work) with some custom work on your behalf. I like it. Smartest post I've seen on this subject. Of course thats compare to re-pete who failed at posting a friggin picture
Looks like you would be giving up some power options since the Thunderbird seat has manual recline.
you posted a link a pic of a vette!
That's so familiar, yet slightly different. It's like the bizarro version of the LS front interior. :shifty:
