Thermostat ?
Cost at Team Ford Parts is about $14 for the V6 and $15 for the V8 plus shipping, probably about the same from Five Star Ford.
Genuine Ford part not an inexpensive aftermarket with questionable quality.
I believe the newer Ford thermostats are designed to fail open not closed if there is a failure.
$25 is the cost of the after market part.
That still doesn't explain why the damn thing costs so much. Does it have an alarm or something?
Quit yur whining. $25 isn't that bad when you consider other brand cars or even some older Ford models. I had an 89 SHO, the Thermostat on that cost me $38 aftermarket back in 1991, probably way more now.
Most foreign makes cost about 2x what a US brand part does in my experience.
My Chebby 350 cost about $25 back in 2001 if I recall.
The plain Jane Stant type thermostats probably cost in the teens but the newer engines seem to require a bit more complicated part.
The LS engine is somewhat exotic and probably low production volume so parts are going to cost more than your every day Crown Vic parts.
I am learning to dislike "exotic engines due to the parts issue.
Good Luck, and it could be worse, try BMW parts
Jim Henderson
