Hi!
The AC system does not heat , setting the temp to max it still blowing cold air.
When i run the auto diagnostic DATC,
the displays turn on all his digits , there no count down or any error message .
Just some noises from the air inlets closing.
No fan noise.
after some minutes , pressing any button the display turn off.
It works fine with cold air ,some times does the "jet noise".
Blower speed works Ok.
heat valve issue ?
where should i start ?
lincoln ls v8 2001.
Best regards!
No fan noise.
heat valve issue ?
lincoln ls v8 2001.
Best regards!
