Ok guys I've got the body almost ready for paint on the LSE so now I've been collected my other goodies for the restoration and I'm hoping you can give me some suggestions. So far I've collected the following parts for the resto:
- New front and rear Monroe struts, isolator seats and mounting kits.
- Eibach lowering kit
- New rear stabalizer links and adjustable tie links
- New rotors, pads, calipers and stainless break lines front and back.
- New wheel studs all around
- I've new tires Nexen N3000 245/45/18 and the 18 inch Alero wheels I picked up on LVC
Now what I'm not sure about and I have not been able to locate searching the site is if there is an aftermarket front stabalizer kit that beefs up the front suspension. Something that is of greater diameter and with bushings that provide for better handling and corner stability up front? Also have I missed anything here is there another suspension component or components I should be considering replacing?
