Temp gauge question
pudgy234
Providence
So when I bought my car about 2 months ago I drove it only a few miles home and parked it. I noticed the temp gauge was just a bit above the N in the word normal. I put a new thermostat in the next day as planned since I was doing the water pump. The gauge now just stays between the A and L and sometimes hits the M in the word normal. To me that just seems low or is that where they sit. Car has great and comes out the vents around 150 degrees. Just lookin for some thoughts
You're probably at about 175. Did you use a 180 degree thermostat? I think you are fine. IMHO, it's not worth worrying about 10 degrees. Mine runs like a top with the temp right where yours is. I think you might be able to see the temp on a code reader if you really wanted to know what it is. Mine shows live data and that is how I know it is 175. I'm not sure if one you can borrow from the auto parts store will show that or not.
Yeah I used a 180 T-stat. I just thought it looked weird being down so low. Every other ford I've owned the temp gauge sits dead center
From prior experience, a fluctuating temperature isn't a good sign. Again, this is from personal experience. Once the car has been running for a few minutes it should reach it's optimum temperature & stay there as long as you run the car. Sounds like you need to burp the system IMO.
I'm pretty sure the system is OK as far any air pockets. Coolant level hasn't dropped off in the bottle. I did a scan and found a coolant temp sensor out of range code. Perhaps that has something to do with it
Because you need to burp it. If you didn't remove the cap on the crossover tube, you did it wrong
I agree. You're crossover cap is where you should be checking the fluid level. If you take it off, after the car is completely cooled down, and it is not full there, then there is air in the system. Add coolant there until it starts to add to the overflow tank (which you said is already at full level). Idle the car up to temp, which means the thermostat has opened. Once up to temp, give both upper and lower radiator hoses a good shake to help purge air out the crossover tube. If the lower hose is hot, then the thermostat is open. Do not remove the overflow tank cap. Don't aggressively squeeze the upper hose. That just gives the illusion that you are purging air. All you end up doing is squirting coolant out the crossover tube and onto your serpentine belt, which is not good for the belt. You might even draw air into the system when you release the squeeze.
Now let it fully cool again, which will take several hours. Check the level at the crossover tube again. Sometimes this takes a few times before you find it full. It took me a couple of days, and now my gauge is very steady.
I will double check but I did check the coolant level from the cap on the cross over tube. Took a good day or so before stayed steady
