Missing Linc'
Its in, over-all the install was quite easy minus the 2 exhaust manifold bolts that broke and had to be drilled out and re-tapped. Ill edit this later with all the pictures and links for the PDF's on the removal and install on a G2 LS8. So far this is the second day that the car has been running and all was good until I really started beating on it, right now the only issue is the SST foot brake to 3K launch, it immediately jumps to 2nd gear after the tires spin a little and then shortly after 3rd. Other than that everything else is smooth. Im uploading a couple cell phone videos to streetfire right now and then Ill embed them into this thread. Hopefully Ill get some better quality ones soon. Over all Im VERY impressed with this mod and youll see in the videos how much better it is coming off the line, absolutely no bog as opposed to a lot from the stock 2200rpm converter. Ill embed a before video as well.
