ladenblowfish
Hey guys, a couple months ago I changed my 1-2 accumulator and switched to mercon v. Ever since then I have a small puddle of trans fluid leaking from the inspection cover on the bellhousing. At first I thought I might have a little fluid left in the bellhousing from when I drained the TC. I dried it out on 4 seperate occasions. Still leaks. Then I thought maybe the drain plug wasn't tight enough. Still leaks. I'm confused now. What could it be? No leaks prior to the fluid change. Also, is there supposed to be a gasket on the TC drain plug? Any help would be great. Thanks
