T Bird shocks?
Sal329
Greensboro
Can rear shocks made for a T Bird mount up to a Mark? Any modifications? What do you use for the upper shock mount?
Yes, I actually have t-bird fully adjustable Konis in my car. What I did was unbolt the mounts from the current shock and burn the rubber off. This will reveal a sort of cone flange assembly. I then added poly bushing for a T-bird from scp to the flange and bolted it right back in. If I can take some pics of how it looks tomorrow I will show you. The amount of play in the poly vs the rubber is phenomenal. With the rubber I could just push the shocks around, with the poly I can barely move them.
That adapter looks like the assembly I'm spoke about that is revealed after burning the bushings away.
