Hello all,
There does not seem to be an easy way to get to the right one and you could damage one of the hoses, bracket or that valve if you pry the wrong way. This is why I don't highly recommend this one at home.
The left one is easy. Take the airbox out and use a long extension with a swivel for the top bolt and the bottom one isn't too bad either, with a 1/4" ratchet and a 13mm socket.
On the right one, you can get to the back bolt with just a small ratchet also, but that front one is buried by some hoses and a control valve attached to a bracket. The trick is removing the correct two bolts that hold the bracket in place. They have 10mm heads on them and one of them is not too easy to get to. Even when you do get them out, you have to do a lot of persuading to get that bracket far enough out of the way so you can get a socket on that bolt. The method I finally came up with to get that bracket out of my way was a piece of string! I tied it to one of the holes and the other end of the string to a frame hole!!! Sounds funny, but I didn't have an extra pair of hands (like they would fit anyway) and it actually worked for me. I used a 1/4" drive ratchet (again) with a very short extension, to get to that sucker. I have pretty long fingers and they aren't fat, but forget getting a good handle on this bolt, or getting in that area to do much. This is where patience and a few breaks might help. Getting leverage to get that bolt loose can be tough. I put a 14mm socket on an extension and put that socket over the ratchet handle. This acts like a mini breaker bar. You won't get more than 1 click of movement at a time this way though as there is not much free space anywhere, but once it is loose, you won't need the breaker. Once you get that old one off, you think you are home free...but, when I went to put the new one on, it was tight. I had to free up the sway bar by removing one of the end link nuts and pushed the sway bar forward while installing the bolts. You have to be careful that you are installing the bolts straight as they will cross thread easily.
Luckieleo, you really can't see these things from under the car without removing the bottom splash guards. Once you get the two side guards off, you can see them. When laying under the car for a long period of time, I lose track of where I am looking sometimes, but if you follow the sway bar from the end link forward, you will finally spot them. Start with the left one so you understand how they come apart so you would have to fiddle with that learning curve on the right side. I just used ramps to get the front end up on this job. No lift.
Sorry...I didn't take pictures of this one!!
