Sway Bar Bushings/ Correct size question
JINT0NIC
IL
Hi guys,
Quick question about bushings size.
What would be the correct one for 2000 LS V6 model?
Sway bar size is 32mm.
Would 30mm/ 9.5171 EnergySuspension size be enough?
Thanks in advance.
Thanks hawk,
I ve read those threads, I am just not sure about the correct size.
It cant be 27mm there..
Anyone else?
9.5171 Is for sport model, not sure if v8 or v6 makes a diff, but a few v8 sport guys got that one
I may be wrong and hopefully someone will correct me if I'm wrong but I think the V6 size is the same as the non-sport.
I'm not sure if there is a sport V6.
Mine is 32 mm. Is it non sport? I read somewhere V6 bars are wider.
Also read, someone fitted 30mm bushings on his v6.
Can someone confirm that?
:confused:
