miatatomark
Following Jamie's instructions on replacing the blend door actuator without removing the steering column. I've found and removed all the bolts/nuts. I'm at the point in the post where you "pull the driver's side of the dash out toward the seat a few inches". Well, it's not giving at all. It's still attached somewhere on that side and I can't figure out where. The passenger side seems loose and ready to pull out, but what did I miss on the driver's side?
