Strut Rod Bushing measurment
Adams97Mark
Chicago
Hello everyone, I am going to be replacing my strut rod bushing and was wondering if I should as others have mentioned in previous posts to measure a item in order to get the arm to its original position. I know alignment is required in general when front end work is done but I am only replacing the strut rod bushing to frame and bushing to LCA along with my stabilizer bar links. I want to wait for full 4 wheel alignment in case i need LCA or other parts in rear suspension as well as cost reasons. I have posted a picture showing the bushing at frame where I believe I should measure the distance from end of strut rod to the washer (A&B), I know the bushings at LCA just get bolted and torqued into LCA but since I am not removing LCA I assume the alignment won't be off if I just keep the bolts at or near the position they are before removal.
