Ok, starting off I have already searched for this problem. Last week when I was out of town my right rear turn signal burned out. So I replaced the bulb and I get into my car and the bulb light on my dash is still on. So I find the fuse in the rear fuse compartment in the trunk and replace it. Before I close my trunk I check to see if the bulb works. Success! It works! I get my trunk reorganized. The next day I go to work and once again the bulb light on my dash is on and I still have no right rear blinker. I then notice that my license plate lights are burnt out. So I replaced lights and the fuse again because the right rear turn and the license plate lights use the same fuse. The bulb holders looked a little rusty and also the outer covers for the bulbs seem to be leaking a little water. So my question would be should I replace both bulb holders and also the outer covers? Would this fix my problem?? Any help is greatly appreciated!!
