Stock Radio issues.
tom-ls
Winnipeg
So the other day i came home and right as i pulled into my driveway my radio shut off, so i figured ill mess with it tommorw if im lucky itll work the next day. Of course it doesnt. But this is what happens the radio will be off, however i can eject cds put them in go threw menu options and even see the time, this happened before to me once already, except the dealer delt with it when i was getting some other things done, and the recipt said the fuse was blown, well i checked fuse 18 and fuse 2 as they both say radio they were fine, has anyone got an idea why the headunit is acting this way? id rather not have to put in a aftermarket i have a few and all the wires i just like the stock look and my steering wheel controls. :(
ah ok it is a fuse its fuse 27 and it keeps blowing ill see if theres any wires that are shorting or somethin.
welp this was a pointless thread i just fixed my shotty wiring and all is good (line output converter)
Not really. Someone else might run into this problem and find your solution.
