Stock HIDS
Dern Humpus
Warrensburg, MO
do they slowly wear out, or do mine just suck? The lenses are a little messed up, but not horrible. I havent completely figured out the aiming either. Are there any online articles on how to aim my 2nd gen headlights?
Is it REALLY bad, like your bulbs are fizzing out? They usually don't blow out at the same time. Your lenses are probably cloudly, just sand/polish them. Aiming? All you need is a little 4mm allen wrench and a level parking lot.
Speaking from the Gen1 set-up, there is a threaded shaft that goes into the headlight back. It has a hex end so you can turn it (sounds like its 4mm but I can't remember exactly). Theres 2 of them on each unit/each side. Turning them clockwise or counterclockwise will pivot the headlight up and down or side to side. You cannot adjust the low beam seperately from the high beam because its all one unit. Once again speaking from a Gen1 perspective.
gen2's are the same way.
one of the screws is for vertical, the other for horizontal. Lows and hig's are not adjustable seperatly.
Mike
