stock brakes
mcafferty
Lakeville
what size are the stock rotors f/r on the LS V8? INCHES? and how do they compair to aftermarket?
not sure what you are asking - the aftermarket rotors are the same size as the stock rotors unless you swap more than just the rotors.
I don't know the stock size off the top of my head.
if you swap the calipers and mounting - then you can upgrade the rotors as well.
StopTech is the only option I know of:
Big Brake Kits
FOUR WHEEL KIT
FRONT: 355 x 32 mm Rotor/ 4 Piston Caliper
REAR: 328 x 28 mm Rotor/ 4 Piston Caliper
Off the top of my head, if I remember right, the fronts are 11" and the rears are 10.5". Measuring them should be easy...if they are off the car; just measure the diameter of the rotor.
mcafferty said:
just wanted to know what the stock size is or how to measure it
Remind me tomorrow when I'm not half asleep. I have my old set in the garage I can measure for you.
