I've replaced on the front suspension.
Upper/Lower Control arms
outer tie rod ends
outer sway bar end links
bushings
The bags were changed over to coils. The coils were bought used and look to be arnott brand. They are also a lowered coil set.
After putting on the front and rear strut rod bushings I got the car re-aligned and got 4 new tires. After I got my last alignment the car was pulling to the right and the mechanic said that it's set right on but it pulls. (this was 9months ago) Recently I went to get the alignment done and it pulled to the right again along with pretty bad high-speed vibration. I started hearing noises from the suspension so I took it back to have them look at it. Both tie rod end links were loose. (VERY LOOSE) So they tightened them up and re-balanced the wheels and re-aligned the car. They said they cannot get the alignment perfect in the front or the back because it's "maxed out". I have the readout but not with me.
The car still pulls to the right and at high speeds the vibration is pretty bad. I would suspect the axle but the vibration is there through a range of speeds and will go away and come back while traveling at the same speed.
I took the car to an empty parking lot and threw her around a bit to see how the suspension felt and there seems to be a dead spot in the turning radius that is a little tougher to turn.
I'm suspecting the struts are shot and getting tokico's will help out but I'm not sure about the turning issue.
any ideas?
outer tie rod ends
bushings
any ideas?
