steering column
dbleb88
Haverhill
Does anyone out there know if the parts from a 2000 ls steering column will work in a mk viii ? Mostly wondering about the potentiometer, looks the same. Thanx Bruce
At first I thought this was silly question, but after looking at the parts diagrams I'm not so sure. The whole column looks similar. Unfortunately Ford doesn't sell the potentiometer for the LS separately, but it would be interesting to find a salvaged one and see if they're compatible.
All,
Potentiometer is the same ! Whole column will work , but steering wheel will have to be recentered !
Good Luck,
Sonny
You were correct Sonny, parts worked fine, thank you. Does anyone know if you can still get the column restraint cables ? Thanx Bruce
